• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    grading parking lot
    331 Views, 5 Replies
    02-03-2010 09:02 AM
    Can someone help me?
    I need to create cogo with elevations for stake out of parking lot. What Is there most efficient way to do this in Civil 3d? Thanks so much.
    Please use plain text.
    *Matt Kolberg
    Re: grading parking lot
    02-03-2010 09:07 AM in reply to: anamyslak
    I assume you've actually designed the lot already with a surface? Just
    place points wherever you want and then use the "Elevations from surface"
    tool to apply the proposed elevations. Then you can export them to your
    data collector.
    Matt Kolberg
    Global CADD Systems - A division of Cansel
    Active Member
    02-03-2010 09:40 AM in reply to: anamyslak
    Hello Matt,
    Thank you for your reply.
    I will try to do this as I don't have much of experience with surfaces.
    Thanks a lot again.
    *Matt Kolberg
    02-03-2010 10:12 AM in reply to: anamyslak
    Good luck.
    Matt Kolberg
    "anamyslak" wrote in message news:6329587@discussion.autodesk.com...
    > Hello Matt,
    > Thanks a lot again.
    Active Member
    02-03-2010 12:09 PM in reply to: anamyslak
    Matt,
    I decided to do this in LDD :-)
    I'm creating points "as I go" - with elevations of eop and top of drainage structures. Do I need to create also pnts with elevations on the sewer structures or storm and eop will be efficient for my surface?
    Then I plan to build surface from pnts that I created and do pnts, create pnts - surface, random points.
    Can you tell me what you think about this?
    thanks
    *Matt Kolberg
    02-03-2010 12:34 PM in reply to: anamyslak
    I guess it really depends if you are planning to have grade breaks at those
    sewer locations. If not, there should be no need to create points there if
    you're planning on making a surface.
    Matt Kolberg
    "anamyslak" wrote in message news:6329763@discussion.autodesk.com...
    > Matt,
    > thanks
