AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
freeze label VIEWPORT OBJECT VISIBILITY CONTROL c3d 2012 64 windows 7
- Highlight
- Email to a Friend
- Report Inappropriate Content
I create many survey maps at 1:100 scale
when showing and dimensioning a found point very close to a corner I have to
exagerate the acutal distance because of the points sizes (The found symbol is several feet wide)
As is typical in a map you can create a detail.
I know how to create a viewport detail showing what I want
but I dont know how to turn off or freeze the label and cogo point / lable on the 1:100 portion of the map
I would like to be able to have a command that says
'select object to freeze in current viewport'
I have tried this search on the this board and google
freezing by layers does not seem to be the answer for a single point or label
I have sincpac and splayfrz freezes more than what I want.
Re: freeze label VIEWPORT OBJECT VISIBILITY CONTROL c3d 2012 64 windows 7
- Highlight
- Email to a Friend
Cansel - Autodesk Division
http://www.cansel.ca/
- Highlight
- Email to a Friend
Thank you, Although its a little more work than I had hoped , at least I know the layer method is currently the best solultion
