• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    DomagojX
    fatal error: unhandled access violation reading
    453 Views, 1 Replies
    09-02-2012 08:47 AM
    fatal error: unhandled access violation reading 0x0000 exception at f551e6h
    this is what i get in civil 3d 2013 64bit running on windows 8 64bit release preview build 8400. I know that it is probably still not fully supported by autodesk but i would appreciate if someone has a solution for this problem.
    Civil 3D loads normally. I can load my dwgs without problems. Pan, zoom works. But when i start to do something like drawing, annotating, modifying it takes less than five steps untill i get fatal error message and civil3d crashes.
    Please use plain text.
    New Member
    Re: fatal error: unhandled access violation reading
    12-10-2012 12:12 PM in reply to: DomagojX
    I'm having the same problem! Did you find a solution yet?
