• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    export xml contours not the same
    84 Views, 2 Replies
    11-27-2012 07:15 AM
    trouble....i'm exporting a surface from 2013 to be used in 2010 for presentation. works great but the contour interval is not the same as the surface i'm exporting. working in 5/25 contours...xml import comes in with 2/10 contours. looked for a setting but can't seem to find. help?
    Please use plain text.
    Re: export xml contours not the same
    11-27-2012 08:03 AM in reply to: acherry
    Contour interval is set by surface style.  What style are you putting the surface on when you import? You can set that style before or after you import, or you can put the surface on a different style as you import, or later.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Member
    11-27-2012 08:56 AM in reply to: troma
    Yes, that makes sense. thank you. I imported the file and exploded it for minor cleanup and presentation before i noticed the contours were not the same as the original. Strange, that when I started a new drawing and imported the same xml file, only the tinn boundary came in, no contours??? I'm kinda new to this 3d stuff and do a lot of head scratching. Sometimes I get the light bulb.sometimes not. Your help is appreciated.
