• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    error message
    114 Views, 4 Replies
    11-05-2012 12:02 PM
    Keep getting error message everytime I try to open a civil 3D 2012 tutorial file.  it says  C:\PROGRAM FILES\AUTODESK\AUTOCAD CIVIL 3D 2012\HELP\CIVIL TUTORIALS\DRAWINGS\POINTS-1.DWG IS CURRENTLY IN USE OR IS READ ONLY.  what do I do?
    Please use plain text.
    antoniovinci
    Re: error message
    11-05-2012 12:09 PM in reply to: othomas116
    othomas116 wrote:
     what do I do?
    First I'd check the READ-ONLY flag of that file in Explorer, then I'd erase every .DWL and .DWK in its directory, sir.
    Valued Mentor
    Re: error message
    11-05-2012 12:38 PM in reply to: othomas116
    The files that are located in the Autodesk directories are marked as Readonly by the installer. I would suggest making copies of the files you want in a different directory. You'll still need to remove the readonly property after you make copies.
    Mike Robertson
    FL. Dept. of Transportation
    CADD Applications Developer
    HPxw4600 Workstation
    Core 2 Duo 2.33ghz, 8gb RAM
    nVidia Quadro FX1700
    Win7 64bit
    New Member
    Re: error message
    11-06-2012 02:01 PM in reply to: michael.robertson
    How do I make copies of files and how do I remove the read only property.  NOT A COMPUTER TECH HERE.  Need more information on how to make the changes
    Valued Mentor
    Re: error message
    11-07-2012 04:08 AM in reply to: othomas116
    I would highly suggest a basic computer course if you don't know how to copy a file. It is a basic requirement of using pretty much any type of computer program.
    Mike Robertson
    Win7 64bit
