• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    aldawg23
    edit lisp for station-elevation of 3d polylines
    311 Views, 2 Replies
    11-19-2012 11:34 AM
    I have a lisp I found online which extracts the x,y, and z of a 3d ployline to a .csv file.  I would like to edit this lisp to extract the 3dpolyline as station-elevation in two columns of an excel file.  My ultimate goal is to extract the data for use in hec-ras.   Is anyone able to do this edit?  Can anyone recommend a lisp tutorial which may lead me down the path to ultimately edit the routine myself?  I have attached the lisp if anyone cares to take a look.  thanks.
    Please use plain text.
    *Expert Elite*
    Re: edit lisp for station-elevation of 3d polylines
    11-19-2012 11:49 AM in reply to: aldawg23
    You'll probably get better answers over here:
    http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Expert Elite*
    11-19-2012 12:54 PM in reply to: aldawg23
    If you're planning to learn AutoLISP only for this one routine, you might consider a workaround:
    Be sure your polyline objects are 3D polylines.
    Use _AeccCreatePtPlylnCtrVertAuto command to create points at the polyline vertices. The elevations will be captured from the polyline.
    Go to Toolbox tab of Toolspace. Expand Reports Manager, expand Points, right click and execute Station Offset to Points. Once you have created the report, select only the data portion of the report (don't select header, etc.), right click, copy. Open Excel, paste.
    Delete the columns you don't want.
    This is not as automatic as a custom program would be, but it's pretty fast and easy, and you don't have to spend  hours learning AutoLISP.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
