• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    dwg topography to 3d solid
    146 Views, 3 Replies
    11-13-2012 04:04 AM
    Hi. I need to create a 3d terrain solid from dwg nivel curves (contours). I tried with loft command but the lines are too detailed and my pc takes a eternity to loft just 2 lines and i have a lot of it.
    I was wondering if use revit will be a good option. Can you please tell me the best way to do it and dont create a extensive 3d file?
    Regards
    Please use plain text.
    antoniovinci
    Start from here, sir.
    11-13-2012 05:28 AM in reply to: Miguel7799
    *Pro
    Re: Start from here, sir.
    11-29-2012 10:39 AM in reply to: antoniovinci
    before he can use that advice he has to first create a C3D surface from the contours.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Re: dwg topography to 3d solid
    11-29-2012 10:48 AM in reply to: Miguel7799
    Are you using Civil 3D? If so, do as the previous poster suggested and create a Civil 3D surface from your contours and then follow AntonioVinci's link.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
