• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    sboon
    Re: direct point inverse - rant
    01-17-2012 02:30 PM in reply to: TerryDotson
    Both 2D and 3D distances would be useful.  Also vertical difference, and slope or grade between points.
    I would prefer to see the inverse reported in Azimuths, instead of by quadrant bearings.
    Thanks Terry.
    Please use plain text.
    Valued Mentor
    TerryDotson
    01-18-2012 08:06 AM in reply to: sboon
    Okay, all that has been added, download the ZIP again and update your VLX.
    IMPORTANT: This routine has not undergone thorough testing and could report incorrect results.  It is simply something we put together quickly for freeware to address the requested problem, it is not based on our time tested MapWorks code.  As such you should scrutinize it's results !!!
    Valued Mentor
    TerryDotson
    01-18-2012 03:31 PM in reply to: sboon
    Toshiba Qosmio X505-Q890
    By the way, I have that same notebook as a test machine.  Very nice but the glossy surface is a fingerprint magnet that drives me insane.
    *Expert Elite*
    01-18-2012 11:40 PM in reply to: sboon
    Spoken like a Sincpac-C3D user...
    I *think* the PTINV command will display azimuths, if that's how the drawing settings are set, but I need to go back and verify.  If not, they'll do that in the next release.  It already does both 2D and 3D distances, along with slope and grade, as well as incorporating the ability to include "running totals".  We've also now incorporated an OSNAPZ toggle in the Status Bar, which Autodesk inexplicably removed after the 2008 (or maybe 2007) release.
    Jeff, Christopher, and I all actually USE Civil 3D in real work, so we understand how important these things can be.  The big question is "What's going on at Autodesk?"  Why do they keep doing things that make life so difficult for C3D users?
    Sinc
    Active Member
    kettledrum
    01-31-2012 11:34 AM in reply to: TerryDotson
    This is a great tool and a godsend.  This is much easier than the solutions available in vanilla C3D.  Thanks!
    *Expert Elite*
    johnm
    01-31-2012 01:19 PM in reply to: TerryDotson
    Thanks Terry!
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    jtroutt
    02-01-2012 05:31 AM in reply to: TerryDotson
    Thanks Terry.  I agree w/Kettledrum.  This program is great and works much better.  Thanks to all for listening.
    Member
    04-15-2013 10:21 AM in reply to: sboon
    It is completely ridiculous that you would have to acquire a freeware routine for such a simple cogo task that Civil 3D should do anyways. Boo on Autodesk. I just purchased C3D through my company and after a few months of the honeymoon with it my production is WAY WICKED down. All the vendors do a great job of pumping it up because they have to. It stinks. I have a long list of all the "it used to do that"
    Windows 7 Professional SP1
    intel CORE i5 vPro i5-3320M 2.60 GHz, 4.00 GB RAM
    Civil 3D 2013
    *Expert Elite*
    04-15-2013 10:35 AM in reply to: dnicholson
    What program were you using previously?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Member
    04-15-2013 11:16 AM in reply to: troma
    LDC2009. Now C3D 2013. I have been using this product since its inception. DCA, Softdesk, LDT, Civil 3D. Autodesk weaves in and out of profiling this software secifically for site development. Autodesk should note that the majority of it's users are not in the subdivision business. I think they are trying too hard to compete with microstation instead of giving its customers what they need and want.
    Civil 3D 2013
