• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    different verticle and horizontal scales
    855 Views, 4 Replies
    12-28-2007 09:02 AM
    any way to change the horizontal scale independent of the vertical scale, the verticle exaggeration cant do it if i am not mistaken
    from the help menu:
    Vertical Exaggeration
    Specifies by how much the elevation values are increased in the profile view for greater visibility. Enter either 1 for no increase in scale or a larger number to increase the scale. The elevation values are multiplied by this value, so a larger number increases the amount of exaggeration in the profile view.
    The drawing’s horizontal scale factor (H) is divided by the vertical exaggeration setting (X) to obtain the profile view’s vertical scale (V).
    For example, if your drawing’s horizontal scale is set to 1”=50’, and you want the profile view’s vertical scale to be 1”=10’, then set the vertical exaggeration to 5.
    Please use plain text.
    *Jason Hickey
    Re: different verticle and horizontal scales
    12-28-2007 09:18 AM in reply to: evansandevans
    Are you looking to exaggerate in horizontal? What are you attempting to
    accomplish with this?
    Jason Hickey
    www.civil3d.com
    www.eng-eff.com
    "j evans" wrote in message news:5809146@discussion.autodesk.com...
    from the help menu:
    profile view.
    exaggeration to 5.
    *wfb
    12-28-2007 09:41 AM in reply to: evansandevans
    Don't fall for it Jason. This is called "Trick the Hickey" !
    Bill
    *Matt Kolberg
    12-28-2007 09:48 AM in reply to: evansandevans
    The vertical exaggeration is controlled by the styles. Profile view styles
    and section view styles have this setting. There is no real drawing scale
    factor in Civi l3D. Sure there's that setting in drawing settings, but
    that's merely a visual thing.
    I'm not sure what else you need.
    Matt
    *Jason Hickey
    12-28-2007 10:23 AM in reply to: evansandevans
    I've always called it "stump the chump" but I like your definition better,
    Bill :smileywink:
    Jason Hickey
    www.civil3d.com
    www.eng-eff.com
    "wfb" wrote in message
    news:5809188@discussion.autodesk.com...
    Bill
