AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
cut/fill volume table for SURFACES
- Highlight
- Email to a Friend
- Report Inappropriate Content
Does anybody know the way to make a cut and fill volume table for a couple of surface ? (ie a volume surface with base surface and comparaison surface)
The only thing I can do is making a surface range volume table but I cannot have cuts and fills in columns.
I hope somebody can help,
Thanks and regards,
Pedro T.
Civil eng.
Re: cut/fill volume table for SURFACES
- Highlight
- Email to a Friend
I found this great tip in the forum :
"Create a volume surface, run an elevation analysis on the surface with two ranges, one negative for cut and one positive for fill. Now create an elevation table for the surface and you'll have what you need. Can't think of any other way to do it." from BrianHailey
now, I would like to write "fill" instead of the "range id" in the table! Possible? or at least a minus sign for cut and plus sign for fill.
- Highlight
- Email to a Friend
All parts of the table are customizable and can have whatever heading text you want to use - edit the table Style and customize away......
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Highlight
- Email to a Friend
PedroTo wrote:I found this great tip in the forum :
Nope, each column can only have one header and it can't change based on the data in the table (you can set the table up to say whatever you want, it just won't automatically change if the column values change from cut to fill). Using this method, you don't get to see cut vs. fill. You can have a cut/fill column that will show you the volumes with fill being a positive number and cut being a negative number.
Check out the new Volumes Dashboard Extension if you are using 2012 (you can read about it HERE).
- Highlight
- Email to a Friend
I need to figure out the amount of cut and fill up to a specific elevation, the Base Flood Elevation. Right now, I am creating the proposed and existing surfaces in Civil 3D and making a fellow coworker convert it to Eagle Point to generate this slice Volume Table. See attached file. Is there a way to generate this type of table in Civil 3D? Any ideas? Thank you!
