• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    curb and gutter, something
    441 Views, 6 Replies
    12-20-2012 12:06 PM
    i need a subassembly that can do what is circled in the image. i need a .5:1 for a base under my curb. my "help" for CIV3D isnt working, so i dont have pictures of my subs and its killing me.
    thanks,
    Please use plain text.
    KMercier_C3D
    Re: curb and gutter, something
    12-20-2012 12:09 PM in reply to: MonkeyTrainer
    Might I suggest looking into the Subassembly Composer. You can make a curb and gutter subassembly pretty simply with whatever input parameters you need.
    Kati Mercier, P.E.
    Co-author of "Mastering AutoCAD Civil 3D 2013"
    AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
    AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
    AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
    *Expert Elite*
    sboon
    12-25-2012 06:31 PM in reply to: MonkeyTrainer
    You might also be able to build what you need using the OOTB subassemblies.
    *Expert Elite*
    12-26-2012 11:21 AM in reply to: KMercier_C3D
    Kati, I went to AU Online to download your handouts, but nothing appears. Do you care to post them here for the community?
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    KMercier_C3D
    12-26-2012 11:53 AM in reply to: tcorey
    Hmmm my 2011 handout should be downloadable from here: http://au.autodesk.com/?nd=class&session_id=9196
    And my 2012 handout should be downloadable from here: http://au.autodesk.com/?nd=class&session_id=10451
    I think you need to be logged in to download? If you are still having difficulties let me know and I will look into it further.
    Kati Mercier, P.E.
    *Expert Elite*
    12-26-2012 10:37 PM in reply to: KMercier_C3D
    Thanks, Kati. I got the docs.
    I haven't read the newest one, Reverse Engineering..., but I read the 2011 doc. It's very clear and easy to understand. I highly recommend it to everyone.
    BTW, Kati, in your AU bio, it mentions you are active in the Civil 3D Subassembly Composer forum. Is that a type or or is there a forum specifically for Subassembly Composer? Where is that? I don't find it anywhere on Autodesk.
    And one more question, Kati, do you cover Subassembly Composer in Mastering Civil 3D 2013?
    Prospero Nuevo!
    Tim
    Tim Corey, Owner
    Redding, CA
    KMercier_C3D
    12-27-2012 06:15 AM in reply to: tcorey
    Thank you for the compliment on the 2011 handout. I am glad that it has been a good resource for you.
    The forum in the AU bio is actually meant to reference this one, the AutoCAD Civil 3D forum, where I often answer questions about Subassembly Composer. To my knowledge, there isn't a stand-alone forum for it currently.
    Yes there is a full chapter on Subassembly Composer in Mastering AutoCAD Civil 3D 2013
    Kati Mercier, P.E.
