• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    djocwf54
    copy blocks from design center
    110 Views, 3 Replies
    01-22-2013 09:58 AM
    Can you open two dwgs and copy blocks from one design center to the other??
    Please use plain text.
    *Expert Elite*
    rkmcswain
    Re: copy blocks from design center
    01-22-2013 10:44 AM in reply to: djocwf54
    There is only one designcenter, but yes you can copy blocks from one DWG to another DWG.
    Only the receiving DWG needs to be open, but you can have both open.
    djocwf54
    01-22-2013 10:57 AM in reply to: rkmcswain
    If you have two dwgs open you can copy things from one dwg to the other thru both design centers. In fact looking for thie block thing i found you can copy layers, linetypes, dimstyles. almost everything. Love this program. Learn something new everyday.
    The block i was wanting to copy is assigned to a point and i will need to figure out how to do that. That is a different story than just inserting a block.
    *Expert Elite*
    rkmcswain
    01-22-2013 11:08 AM in reply to: djocwf54
    But to repeat, there is only one "designcenter". It's a palette, it doesn't belong to a drawing.
    So you can have 20 drawings open and there will only be one designcenter.
    And only the receiving drawing has to be open
