• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    command not recognized after Civil 3d SP1
    112 Views, 4 Replies
    01-15-2013 05:26 AM
    I just downloaded SP1 to mi Autocad Civil 3D (spanish), but now when i try to order some objects behind others it shows "Comando BACK no reconocido..."  (Command BACK not recognized), i have tried to repaired the installation, reinstalled, unistalled and reinstalled, and the problem stills, so i guess it was the SP1 that change the language pack.
    Please use plain text.
    Active Member
    Version: CIVIL 3D 2013
    01-15-2013 07:11 AM in reply to: technetic
    civil 3d 2013
    *Expert Elite*
    Re: Version: CIVIL 3D 2013
    01-15-2013 07:23 AM in reply to: technetic
    Are you typing that command?  What happens if you use the command from the Ribbon or a Toolbar?
    BACK is not a command in English version, obviously I don't know about the Spanish
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Active Member
    Re: command not recognized after Civil 3d SP1
    01-16-2013 07:16 AM in reply to: technetic
    I usually use right click> draw order, i didn´t try the command on the ribbon.
    I reinstalled Civil 3D but not SP1 and it works fine now, but i would like to install it anyway, i think i´ll wait for a hotfix on that
    THANKS
    Active Member
    01-16-2013 07:20 AM in reply to: technetic
    I use SPANISH version of civil 3D, and i don´t know if it occurs in other languages versions
