Edits and changes to the code set style sometimes do not update in the corridor properties code tab and the quantity takeoff report:
1) assign payItems to the pave links, and create a QTO report, the quantities are correct (there are 4 items for Pave2 but they sum to the correct value), then 2) change the payItem, run a report, and again everything is OK with the QTO report updating correctly.
The issue begins when I then:
To correct this, I must delete the code set style and remake them and sometimes create a new payItem file with new payItem IDs.
attached is the corridor model
