• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    aluko0719
    Accepted Solution
    civil 3d 2013 how to change static to dynamic in profile views
    445 Views, 4 Replies
    05-03-2012 09:33 AM
    in civil 3d 2013 i have a existing surface, alignment, and profile that is data linked into another drawing when i create a profile view from the profile data link when i get to the profile display options under update mode it shows as beening static, i don't want it to be static i want it to be dynamic. is there a way or setting that will let me change that to static? we show the existing grade as hidden but with the static option set the grade shows up with long and short
    Please use plain text.
    *Expert Elite*
    BrianHailey
    Re: civil 3d 2013 how to change static to dynamic in profile views
    05-03-2012 10:28 AM in reply to: aluko0719
    Unfortunately you can't. The current workaround is to datareference in the surface and then create a surface profile in that drawing for your alignment. This way if the surface changes, the profile changes and you can use linetypes.
    Active Member
    aluko0719
    05-06-2012 04:54 AM in reply to: BrianHailey
    thanks for the answer. i hope they fix this in a patch. in 2012 the line comes in as dynamic.
    *Expert Elite*
    05-06-2012 07:08 AM in reply to: aluko0719
    aluko0719 wrote:
    ... in 2012 the line comes in as dynamic.
    It has never been dynamic for me, in C3D2007-C3D2012. I have always used the same method Brian described.
    Jeff_M, also a frequent Swamper
    Active Member
    aluko0719
    05-06-2012 11:23 AM in reply to: Jeff_M
    for us, in 2012 it always data linked as dynamtic and you could change it static
