• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    catchment area
    768 Views, 5 Replies
    02-07-2011 08:44 AM
    is the catchment area tool like the water drop tool except backwards? if i pick a point on my suface i would think it would give me the area that's flowing to it, like a watershed. it does this somewhat but it's not giving me what i think should be an acurate pline around the area. when i pick a point it should cover the whole side of a hill but it gives just a small area. i've picked a lot of places on the hill but the results are the same. i can't find any settings to maybe tweak the output.
    Dell Studio XPS 9100
    Intel Core i7 CPU 930 @ 2.8GHz
    12GB Ram
    64 bit
    C3D 2012 SP2
    Please use plain text.
    Distinguished Mentor
    Re: catchment area
    02-07-2011 09:02 AM in reply to: nostupidquestions
    I'd look at the triangles of the surface to see if there are any flat spots that are causing the catchment tool to not make it up the hill. Maybe put a slope label on the triangle to see if it's flowing the correct direction towards the low point.
    Christopher
    Re: catchment area
    02-07-2011 09:12 AM in reply to: Civil3DReminders
    i'm sure there a bunch of flat spots. it's quite a large site and the contours are derived from contour polylines. i was hoping there was a setting somewhere. i'm trying to find the top of the basin that's draining to our road. i just used the waterdrop tool and defined the ridge that way. my computer isn't powerful enough to use the watershed surface display. thanks anyway.
    12GB Ram
    64 bit
    C3D 2012 SP2
    Employee
    Matt.Anderson
    Re: catchment area
    02-07-2011 07:30 PM in reply to: nostupidquestions
    If you review the user assistance, it is recommended that you use the water drop together with the catchment area to define the overall area.
    Matthew Anderson, PE
    Business Consultant
    Global Services
    Autodesk, Inc.
    *Expert Elite*
    Joe-Bouza
    Re: catchment area
    02-08-2011 05:10 AM in reply to: nostupidquestions
    Turn on the flow arrows of your surface to review the catchments area; if your surface definition has any vaugaries in it the catchments will pick them up. As Matt mentioned the tool works in conjunction with the water drop.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Valued Mentor
    fcernst
    Re: catchment area
    12-19-2012 04:40 AM in reply to: Matt.Anderson
    "If you review the user assistance, it is recommended that you use the water drop together with the catchment area to define the overall area. "
    For years, this has been a tedious and very unelegant workflow suggestion. It is sophmoric and crude...
    We need better basin analysis tools that think like an engineer and can see the drainage basin picture. We need surface drainage tools that allow the engineer to quickly achieve the level of basin discretization that the engineer is needing to achieve for the situation.
    Usually this is aggregating the surface slivers these C3D surface routines typically produce for us, and expanding outward like the OP suggested.
    Back to the drawing board for C3D programming...quickly get a surface algorithmist on this who understands what we have been frustrated with for years...
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
