• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    can we create contours from JPEG file in Civil 3D?
    436 Views, 10 Replies
    12-04-2012 03:19 AM
    I've an old countour map (hard copy drawn ages ago) which now I want to digitize.
    I've scanned this map (can be saved in JPEG, PDF etc format) however I don't know if there is an easy way to create contour lines from this JPEG image.
    really appreciate inputs in this regard.
    Please use plain text.
    antoniovinci
    Re: can we create contours from JPEG file in Civil 3D?
    12-04-2012 04:09 AM in reply to: kingaonkaras
    The easiest way is to vectorize 'em automatically by means of the free Wintopo, then in Autocad you assign elevation to the resulting contours.
    12-04-2012 10:29 AM in reply to: kingaonkaras
    Quite frankly, if you are not planning on doing this very often, just scale it (properly) and trace with polylines.  You will be waaay ahead.
    Bill
    Joe-Bouza
    12-04-2012 02:42 PM in reply to: wfberry
    Hi Bill,
    Saw your quotes on the *EE* video by Brian Kling. Way to go! Excellent and congrats <G>
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Neilw
    12-04-2012 03:27 PM in reply to: kingaonkaras
    Raster Design has a contour follower in the vectorization tools. It will create polylines with elevations as a best fit to the raster pixels. It's not perfect but probably better than manual tracing. See the Raster Design help file for the contour follower tool.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    AllenJessup
    12-05-2012 07:08 AM in reply to: wfberry
    I'd agree that tracing is a good option for the occasional project of this nature. As mentioned Raster Design and other programs will do this type of work. However they usually need human intervention unless you have a very clear image. So between the cost and the fact that it would probably not be a automatic as you hope. Tracing on screen is a good way to go.
    If you do trace on screen. You can save some time by setting the Elevation variable to the contour elevation before you start to draw each polyline. Remember to use 2D polylines as elevation.
    Allen
    Joe-Bouza
    12-05-2012 07:20 AM in reply to: AllenJessup
    If you have a clean image there are some PDF to DWG converters with free trials like THIS ONE. you still have to set the elevation.
    You can clean things up preyy easily in raster before convert.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    New Member
    12-05-2012 08:55 PM in reply to: AllenJessup
    Thak you all for your replies.
    Yes, this is one off project where I need to do this and requirement for accuracy probably dictates the method to be adopted...so I guess doing it manually is the best fit.
    thanks again.
    antoniovinci
    12-06-2012 01:46 AM in reply to: kingaonkaras
    Kinga, please pay attention to the mentioned freeware Wintopo, 'cause it's well-suited for "line art" like raster contours.
    Finally it may convert the result not only to vector DXF but also to shapefile, to which you can add geometric fields as area or length with opensource software, e.g. Qgis.
    neilyj
    12-06-2012 04:48 AM in reply to: kingaonkaras
    I've used Wintopo and it does a reasonable job although I imagine the quality of the output will depend on the quality of the jpeg used
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
