• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    breakline triangles
    196 Views, 6 Replies
    01-14-2013 05:59 AM
    I have a area of surface at a constant slope. When I only use the end points to create triangles(white) c3d returns an incorrect elevation when hovering over the surface. Is there a way to make c3d add triangle points along a breakline at an interval automatically without using the add elevation point tool? I need triangles like the red ones but only want to create/set a couple key elevation vertices (blue dots).
    Thanks.
    Civil 3D 2012 SP3.0 Windows 7 Enterprise 64-bit
    Dell M6600, Core i7 @ 2.3GHz, 16 GB ram
    Please use plain text.
    *Expert Elite*
    Re: breakline triangles
    01-14-2013 06:11 AM in reply to: lambertb
    Check the "supplementing distance" in the dialog box for adding breaklines.  Make it smaller to add more points.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Valued Mentor
    01-14-2013 10:21 AM in reply to: lambertb
    Under the Modify tab of the Ribbon, select "Insert Elevation Point." (See attachment.) Select the feature line and type in the letter "I" to allow inserting points at an incremental distance apart. Type in the distance that you want between elevation points and they will be automatically inserted. Repeat for each feature line.
    01-16-2013 07:06 AM in reply to: castled071049
    Thanks.
    Do the elvation points update if I change the vertex elevation?
    Thanks.
    *Expert Elite*
    BrianHailey
    01-16-2013 07:28 AM in reply to: lambertb
    lambertb wrote:
    Thanks.
    Thanks.
    If you add points to your feature/3d pline they won't update if you chang the end elevation. If you do as Troma suggested, the surface will update the suplimental distance points added when it recalcs the surface.
    01-16-2013 09:48 AM in reply to: troma
    I wish to change the supplementing distance. I can't select the features and reimport as breaklines as I get a message, The features are already in the surface. Without figuring out every breakline set and deleting the 1 or 2 features from that and reimporting, is there another way to change the supplementing distance?
    Thanks.
    *Expert Elite*
    01-16-2013 09:59 AM in reply to: lambertb
    I don't think there is a way to do this after they are added to the surface, sorry.  I've been looking for that option myself.
    Here are a couple of options:
    1. Go with the option of adding verticies.  Note that this will mess up any labels on the feature line.  The verticies won't automatically update to maintain one slope, but you can use a button in the elevation editor to do that.
    OR
    2. Delete the feature lines.  Rebuild the surface. Run the OOPS command to bring the feature lines back.  Then add them to the surface with the right settings.
