• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    bak file not created
    192 Views, 4 Replies
    11-07-2012 07:44 AM
    please help,
    my civil 3D 2012 doesn't save BAK files. "create backup copy with each save" is ticked in option menu, but it doesn't create BAK. My file crashed yesterday and I lost one day work.
    Anybody have a solution for this?
    thanks,
    Shahrokh Sobhani
    Civil Engineer
    SNC Lavalin Inc.,
    Toronto, Canada
    Please use plain text.
    antoniovinci
    Re: bak file not created
    11-07-2012 07:56 AM in reply to: sobhani_sh
    Please call your IT department: they're gonna find those .BAK in your hard disk, unless you saved directly on network server without full permissions.
    Distinguished Contributor er
    11-07-2012 08:07 AM in reply to: sobhani_sh
    Another option is check the path in the MOVEBAK command. Someone my have changed the path associated with it. I always set the MOVEBAK path to a location in my machine so all my bak files are in 1 location.
    11-07-2012 08:12 AM in reply to: sobhani_sh
    Set ISAVEBAK to 1. If set to 0, no backup is created.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    11-07-2012 08:19 AM in reply to: sobhani_sh
    when i saved the file I got this message at command line:
    qsave Unable to transmit selected drawing file.
    lynnnester had answered this in another post and it worked :
    You'll get that message after changing the save location for the .bak files.  By default, AutoCAD creates the backups in the same directory as the drawing, so I'd say someone changed the save location with MOVEBAK (Express Tools > File Tools > Move Backup Files)
    Shahrokh Sobhani
    Civil Engineer
    SNC Lavalin Inc.,
    Toronto, Canada
