• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    assembly problem
    79 Views, 4 Replies
    10-24-2012 07:22 AM
    i've got several assemblys built for a road project. the problem is whenever i modify an assembly by adding a subassemby, some of the existing subassemblies move. they stay attached to the assembly but they disconnect from the part they were attached to. i can move them back so the assembly looks correct but when i rebuild the corridor chances are they show up wrong. i've tried 'move to' and just grabbing and snapping. i can eventually get it attached but not without trial and error. i'm running c3d2012.
    Dell Studio XPS 9100
    Intel Core i7 CPU 930 @ 2.8GHz
    12GB Ram
    64 bit
    C3D 2012 SP2
    Please use plain text.
    Valued Mentor
    owenmull
    Re: assembly problem
    10-24-2012 09:10 AM in reply to: nostupidquestions
    How have you attached the subassemblies to your assembly? Did you just grip edit and snap? Or did you use the 'Add to Assembly' command on the ribbon?
    If you simply grip edited and snapped your subs to the assembly, then they aren't really attached to it, causing your corridor to not use all of your subs. Check that and get back to us.
    -Owen
    Windows 7 x 64 bit
    ATI FirePro V4800 Triple Monitor
    12 GB RAM
    Intel Xeon W3550 @ 3.07 GHz
    Civil 3D 2012 SP 2
    ______________________________________________________________
    Intel inside. Idiot outside.
    Usually, I find that the problem is between the keyboard and the chair.
    10-24-2012 09:14 AM in reply to: nostupidquestions
    I have found 2012 to work intermittently like you say. You can get it work after some time, but it can be cumbersome.
    Just FYI, 2013 has an Insert option during placement of subassemblies and it works great. You can specify Before or After a particular existing subassy and all other subs move over accordingly.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    10-24-2012 09:25 AM in reply to: owenmull
    the assembly was built and worked fine. i had to add a widening subassembly between two subassemblies. all the subassemblies stay attached to the assembly but they don't reconnect to each other properly.
    12GB Ram
    64 bit
    C3D 2012 SP2
    10-25-2012 07:50 AM in reply to: nostupidquestions
    Usually see this when the AutoCAD MOVE or grip edit move commands were used to relocate subassemblies, instead of the Move To command that is available on a subassemby's shortcut menu.  Fix by using the Move To shortcut command to reassemble them in the correct order.
    David Zavislan, P.E. | CAD Manager / Associate | NV5 | www.nv5.com
