• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *alex
    alignment has not tick marks
    107 Views, 2 Replies
    05-17-2005 12:38 PM
    I opened a dwg and made an alignment in it but there are no tick marks on
    it. I went through the alignment styles and see no place to set it.
    i can open the tutorial dwgs and tick marks are there. Any suggestions how
    to get them to show? Thanks, alex
    Please use plain text.
    *Daniel Philbrick
    Re: alignment has not tick marks
    05-17-2005 12:58 PM in reply to: *alex
    Alex,
    That is actually part of the Station Label Style. Start a drawing from the
    _Autodesk Civil 3D Imperial ByStyle.dwt and expand the Alignment, Major
    Station label collection. There is a style in there called "Parallel with
    Tick". If you edit that label style and the select the Layout tab you will
    see a Component called the "Tick". That is a label style which already has
    the tick. If you want to add the tick, drop down that control next to the
    component name field and you will see "Tick" in that list.
    Dan
    "alex" wrote in message
    news:4847963@discussion.autodesk.com...
    *alex
    05-17-2005 01:52 PM in reply to: *alex
    thanks a lot.
    "Daniel Philbrick" wrote in message
    news:4848015@discussion.autodesk.com...
    Alex,
    Dan
