• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    mccabejoshua
    add a bug to the list
    247 Views, 6 Replies
    12-28-2012 09:01 AM
    my C3D11 is having one hell of a time sorting survey points by description.  I crash everytime I open a drawing, open a survey database, edit points, sort by description.
    Happy New Year!
    Please use plain text.
    Valued Contributor
    Re: add a bug to the list
    12-28-2012 10:46 AM in reply to: mccabejoshua
    I have not had that problem, but have only sorted within the drawing, not in a database, and have only had about 5000 points.  Do you have any special characters that may cause and issue, expecially the quote, apostrophe, and sometimes the # symbol?
    Hope this gives you a place to start looking.
    Surveyor Lee
    mccabejoshua
    12-28-2012 11:44 AM in reply to: SurveyorLee
    Ha! I only have a few hundred points in this job!
    I have sorted my points in the database in the past so I don't know what is going on here.  I even opened a new dwg and imported my stuff from scratch and It still bugs out.  I really don't want to start another "Autodesk Hates Surveyors" thread(I am the ONLY civil 3D advocate in a Bentley dominated office).  I do love getting laughed at by all the Microstation users when I am cursing C3D from my cube.  I love even more when I have to use Microstation then admit how much better it performs than C3D
    I will try other jobs and databases but I am out of patience for the year with this glitchy, buggy, overpriced, over-rated, new-version-before-the-old-version-is-fixed so-called program. (sigh)
    Happy New Year!
    *Expert Elite*
    12-28-2012 11:46 AM in reply to: mccabejoshua
    Sort on Raw Description instead of Full Description.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    sboon
    12-28-2012 04:02 PM in reply to: mccabejoshua
    Upload the point file, and maybe your drawing so that others can take a look at it.
    Valued Contributor
    01-02-2013 06:01 AM in reply to: mccabejoshua
    If this is the same crash (bug) while trying to do various things in the Point Editor or Survey Point Editor screen that we had a while back, it was taken care of when we installed Update 2 (version 3) of 2011. The Survey Point Editor only has a "Description" column that shows the raw description in 2011. The Point Editor does have both.
    Civil 3D 2011
    Windows 7 Prof. x64
    HP Z400 Workstation
    Intel(R) Xenon(R) CPU
    W3550 @ 3.07GHz
    6.00 GB RAM
    mccabejoshua
    01-07-2013 09:23 AM in reply to: mccabejoshua
    Thanks for the replies.  I appreciate the help very much, unfortunately I have not had time to check these suggestions.  When I do I will be sure to accept the solution.
    Thank you all
