• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    acaddoc.lsp not loading in 2013
    338 Views, 6 Replies
    11-12-2012 08:44 AM
    I have one pc that is not loading the acaddoc.lsp file we have setup company wide.
    Several other pc's that have 2013 load the file fine.
    I did a find file on the rogue pc and it finds the correct file.
    When we start a new drawing on this pc, I get this message:
    ; error: no function definition: AUTOLOAD
    Why would it work on other pc's but not on this one.
    The setups were the same on all.
    Mike
    Mike Porter
    www.ppeng.com
    Civil3D 2013
    Win 7 Professional - 64-bit
    HP Z400
    Xeon W3550 @ 3.07Ghz
    8GB of RAM
    Nvidia Quadro FX 3800
    Please use plain text.
    johnm
    Re: acaddoc.lsp not loading in 2013
    11-12-2012 09:21 AM in reply to: mikepo
    Is it possible that this rogue PC is finding a different file and perhaps that file has incorrect syntax?
    Acad will load the first acaddoc.lsp file it finds. Acad will look in the support folders starting at the top of the list (see attached). If your desired acaddoc file is in a path that is not at the top of the list, acad may be loading an acaddoc file in a secondary support path.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    11-12-2012 09:26 AM in reply to: mikepo
    AUTOLOAD is not a C3D, or AutoCAD, command. This tells me that the acaddoc.lsp has a call to this command which is defined in another custom lisp or dll that is not getting loaded prior to being called.
    11-12-2012 09:35 AM in reply to: johnm
    Looked through the complete search paths.
    No other acaddoc.lsp that I can find.
    I'm going to try deleting lines of the acaddoc.lsp file and see if I can figure out which line is causing the error.
    Thanks.
    Mike Porter
    www.ppeng.com
    Civil3D 2013
    HP Z400
    8GB of RAM
    11-12-2012 09:37 AM in reply to: Jeff_M
    Autoload is a LISP command and it works on all the other 2013 pc's I have installed. (over 30)
    Everyone's installation is the same.
    I'm going to uninstall the profile and reinstall, then try it again.
    Thanks.
    Mike Porter
    www.ppeng.com
    Civil3D 2013
    HP Z400
    8GB of RAM
    11-12-2012 01:02 PM in reply to: mikepo
    I figured it out!!
    For some reason, he was missing the file search path that loaded acad2013doc.lsp
    Added that search path and it works fine.
    Mike Porter
    www.ppeng.com
    Civil3D 2013
    HP Z400
    8GB of RAM
    neilyj
    11-12-2012 01:41 PM in reply to: mikepo
    mikepo wrote:
    I figured it out!!
    acad2013doc.lsp is a very different file from acaddoc.lsp
    neilyj
    (No connection with Autodesk other than using the products in the world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
