• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Zooming Cancels Save As command?
    109 Views, 3 Replies
    02-01-2013 09:10 AM
    I am trying to "save as" a dxf several shapes in a drawing.  Except that when I use my mouse wheel to zoom in, I get this odd message:
    "xxx.dwg" has a command in progress.
    Hit enter to cancel or [Retry]: *Cancel*
    Never had this happen until this morning.
    Any thoughts?
    Please use plain text.
    *Expert Elite*
    Re: Zooming Cancels Save As command?
    02-01-2013 09:18 AM in reply to: NoXrefs
    Is this a one-off, or every time?
    Restart the program
    Reboot the machine...
    let us know what you've tried.
    I first ran into the "command in progress" error when I was messing about in 3D orbit.  Try searching the web for "Command in Progress", it's been around for a while.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Member
    02-01-2013 09:36 AM in reply to: troma
    Thanks for the response.  I rebooted, still having the problem.  I looked up some other pages, and the issue is not related to tables.
    here is what I see if I type the 2 suggested check commands
    Command: cmdactive
    CMDACTIVE = 1 (read only)
    Command: CMDnames
    CMDNAMES = "SETVAR" (read only)
    I've saved as a new drawing, same set of stuff.  The issue is when I try to save dxfs from shapes within.  Is the (read only) something to look into?
    *Expert Elite*
    02-06-2013 08:53 AM in reply to: NoXrefs
    Sorry I missed replying sooner.
    Don't think that's a problem.  Some sysvars are editable and some are read only, just the way it is.
    Sorry I don't have any more suggestions.  Hope someone else can jump in here & help.
