• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Accepted Solution
    Z distance in inches not feet
    212 Views, 7 Replies
    12-11-2012 11:12 AM
    I have a very simple surface. All of the elevations defining it, are set in feet. When I click on the surface it tells me my max and min elevations are in feet matching the points that I have defining the surface.
    Here is the kicker, when I run a distance it is measuring the Z distance in inches and not feet. As you can see by the attached image the distance is 95' but the elevation change is 1 3/8".  The actual points defining the surface are 1.28' difference. If I were to do a spot elevation on the surface, it would give me the correct elevation in feet.
    Can anyone tell me whats going on? I am guessing that this is some sort of variable that I have missed, but damned if I can find it.
    Thanks in advance for your help.
    Please use plain text.
    *Expert Elite*
    Re: Z distance in inches not feet
    12-11-2012 11:17 AM in reply to: ajfernandes
    Try setting your units to decimal feet rather than feet & inches.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    12-11-2012 11:27 AM in reply to: troma
    Unfortunately that didn't work. It just changed my measurements to inches instead. But kept the z measurement the same.
    Any other ideas?
    *Expert Elite*
    12-11-2012 11:31 AM in reply to: ajfernandes
    Can you repeat the screen shot with the new units setting?
    12-11-2012 11:36 AM in reply to: troma
    Here is a screen shot of the units set to decimal instead of architectural.
    *Expert Elite*
    12-11-2012 11:42 AM in reply to: ajfernandes
    I've always worked in metric so I don't really know how the imperial settings work in C3D, but I know that it is always meant to be feet, not inches.  It looks like all your distances are off by a factor of 12, so you may have started up wrong from the begining, I don't know.
    Could really do with someone else jumping in here to help, but unfortunatly when the topic is marked as solved others may not look into it.
    12-11-2012 12:14 PM in reply to: troma
    Your advice lead me to the solution. Our office has been bouncing back and forth between imperial and metric and I don't have enough experience to do this successfully.
    Here is the solution. Autocad wants the drawing in Decimal Feet. I went back and scaled down the drawing by 12 so that all measurements of units were in feet. (I.E. 9.50' instead of 9'-6") Now scaling the drawing also scales the Z elevation so I had to follow the following link to redifine my points after I scaled. See this thread for how to do that (http://www.civil4d.com/2009/10/scale-your-points-keep-the-elevations/)
    And now, everything makes sense again.
    I'll have to reset my viewports, but small price to pay.
    *Expert Elite*
    AllenJessup
    12-11-2012 12:24 PM in reply to: ajfernandes
    Make sure that you are setting your units correctly in the Drawing Settings. Go to the Toolspace and on the Settings tab - Right click on the active drawing and select, Edit Drawing Settings. Set up your units on Units and Zone tab and check 'Set AutoCAD Variables to match'.
    Here is how I have mine set up for feet
