• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Xref'd Dragged State surface elevation annotation markers don't show up
    160 Views, 0 Replies
    05-03-2011 01:59 PM
    We modified a surface elevation label so that the dragged state shows a Dot marker instead of a closed_filled arrowhead.
    It shows up fine in our base file, but when it's xref'd into sheets the marker disappears and the leader line is pulled back from the feature point. Images are attached showing the area in each of the drawings.
    Maybe there's a global setting or definition for the Dot maker that I can't find, causing it to not display. I've checked the usual suspects such as frozen layers and ambient drawing settings with no luck.
    Does anyone have ideas to make the dots show up in the sheets as they do in the base file.
     - Aaron Lance
    Please use plain text.
