• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Accepted Solution
    Xref Lines are not showing
    103 Views, 4 Replies
    01-10-2013 08:02 AM
    Hello There,
    I have x'ref a dwg. file in my current drawing. And when i print preview with the correct ctb style... The x'ref lines are not showing up?
    Can anyone tell me how can i fix this? I have pretty much tried everything...
    I am having troubles showing the green, cyan and yellow color. when i print preview it doesnt show nothing. The true color is on RGB.
    Please use plain text.
    Valued Contributor
    Re: Xref Lines are not showing
    01-10-2013 08:22 AM in reply to: shinysingh
    Can anyone please help me ASAP..
    *Expert Elite*
    johnm
    01-10-2013 08:25 AM in reply to: shinysingh
    Does the xref reside on a layer that is set to NoPlot (like the defpoints layer) or on a layer that is frozen in that specific viewport (vpfreeze variable)?
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Valued Contributor
    01-10-2013 08:26 AM in reply to: shinysingh
    Never mind, i found the solution. when i xref the file, i selected the no plot layer. that's why it wasn't showing up in print preview...
    Valued Contributor
    01-10-2013 08:29 AM in reply to: shinysingh
    Yes, you are right, John. I was on wrong layer. Thanks
