• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Neilw
    XREF's with raster images
    350 Views, 7 Replies
    11-17-2011 03:47 PM
    Has anyone heard complaints about how XREF's with raster images take forever to load and unload? Anytime you select the XREF in the Xref Manager the images process, whether they are turned on or off. When did this behavior start?
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Please use plain text.
    Joe-Bouza
    Re: XREF's with raster images
    11-17-2011 06:44 PM in reply to: Neilw
    Well, 2004 is probably the first time I saw an aerial image in a drawing file and I've been waiting for images to "process" ever since.
    What is your rasterpecent and rasterthreshold set to?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Neilw
    11-17-2011 07:44 PM in reply to: Joe-Bouza
    I've never messed with those variables Joe. In the 2004 XREF dialogue there is no processing when selecting an XREF. I haven't used any versions since 2005 to any extent up until now so I don't know when the dialogue behavior changed. When did images start appearing in the xref dialogue? That is probably when this became a problem.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    Joe-Bouza
    11-18-2011 05:27 AM in reply to: Neilw
    http://www.appliedtg.com/techblog/index.php/2010/04/26/improving-plotter-performance/
    not sure when, maybe 2010?
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    Active Contributor
    10-04-2012 03:00 PM in reply to: Neilw
    I'm not sure if you ever solved this problem... I came across it in an effort to eliminate the image from processing when I roll over it in the xref manager.  The only solution I've had any success with is to turn off the Tooltips in Options>Display.  Since the reference preview doesn't come up, the image doesn't process for the the preview, unless you have the preview pane active.  I was hoping to find something specific to just eliminate the preview, but I haven't found it yet.
    Ben Zismann
    Neilw
    12-19-2012 03:45 PM in reply to: Neilw
    This behavior is still driving me nuts. I have large aerial images in some of my files that take forever to load. Does anyone have a solution?
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    Neilw
    01-10-2013 02:05 PM in reply to: Neilw
    A big thanks to Autodesk support specialist Zac Travis for finding this blog post :http://www.cad-addict.com/2009/02/autocad-getting-back-old-xref-manager.html
    It explains how to initiate the old XREF manager which did not include raster images. The command is CLASSICXREF. This solves the problem.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    01-10-2013 05:34 PM in reply to: Neilw
    Aha! Thanks, Neil.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
