• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Neilw
    Re: Working with MrSids aerials are really slow Civil 3D 12 & 13
    01-10-2013 01:58 PM in reply to: TRogers
    Sometimes the links posted on blogs and websites are not the actual link to the server but rather to the metatadata for the servers. If you have problems with the links you should open it in a web browser to see it's contents. If it is indeed just the metadata then you can usually find the WMS link address in that metedata. Just copy and past it into the Map WMS connection.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Please use plain text.
    nsummitt
    01-17-2013 01:40 PM in reply to: lissaucad
    I have to disagree with you completely.  FDO connection is much much much slower (to the point of almost useless) rather than attaching the image using imageattach.
    The FDO raster is a joke on Map2010 3D.  If you have a half an hr (slight exaggeration) to let it load when you zoom in you will be fine, but if time is precious and you want accurate placement.  Bring the image in the fdo and mark the four corners.  Then attach the image as an image and rubbersheet the corners of the image to the one that were marked on the FDO.  This way, placement stays accurate and you get a much better response time once the image is inserted, plus other, non-map version of autocad can see the image this way....
    *Expert Elite*
    Neilw
    01-17-2013 04:44 PM in reply to: lissaucad
    One factor to consider when working with SID files is they use a compress/decompress algorythm to display the image and adjust the resolution as you pan and zoom your drawing. So while SID images are smaller and load faster than uncompressed images, they tend to slow down Autocad while you work.
    The alternative is to use umcompressed images which use more disk space and take longer to load, but performance can be somewhat better once loaded since there is no need to decompress. There is also the option to use images that have been decimated to reduce file size (and quality). The challenge is to balance performance vs. file size and resolution.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
