• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Widenig Curves
    230 Views, 3 Replies
    05-04-2012 08:49 AM
    Hi All,
    Im using Civil 3d 2012 and I couldnt find the function that I could offset the smooth curve aligment as shown on the attached pdf. I've looked thru the offset alignments but those linear, curve-cuve-reverse curve, curve-line curve doesn't help much. I would appreciate it if anyone might know the solution.
    Regards
    Please use plain text.
    Re: Widenig Curves
    05-05-2012 05:16 AM in reply to: wilwil02
    You will probably need a spiral.  It appears you probably have a "varying" radius.
    Bill
    BrianHailey
    Re: Widenig Curves
    05-05-2012 07:46 PM in reply to: wilwil02
    When applying a widening through a curve it does not create a smooth transition. It segments it along the curve (I believe in 3 segments).
    After a bit of testing, I've confirmed this:
    The green line is the alignment and the white line is the offset alignment that transitions it's width from start to end of curve.
    Distinguished Contributor
    Re: Widenig Curves
    10-26-2012 08:25 AM in reply to: BrianHailey
    Has anyone figured out a way to dynamically increase the smoothness of the transition? Or an I stuck doing the transition manually to get it to look right? Seems like there should be a setting somewhere for this.
    Civil 3D 2012
    Windows 7 Pro (64bit)
    Intel Xeon W5580 @3.20GHz
    12gig RAM
    NVIDIA Quadro 600
