AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Why does my linetype change if i rotate passed 180 degrees?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can't get this to work at all...![]()
(No connection with Autodesk other than using the products in the world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If either of you want to email me a jessupa at co.rockland.ny.us I'll send both files to you.
Attached is a file created in 2012 and saved to 2007 with the linetype shown in it.
Allen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i see..
ok im getting bad definition on line 2. i copied yours exactly.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've reviewed the creation of custom linetypes from the 2012 help files. The only difference I see is that they now specify the the .SHX extension. Like this:
*FENCEX,Fence with Xs
A,1.0,-0.09848,[FENCEX,FenceX.shp,s=.05],-0.09848,
I also see that in the original post I said to rename the the file to a .SHP file. It should be a .SHX file.
Allen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Still no luck - I'll try again tomorrow with fresh eyes...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
you need to compile the shp file first.
In autocad type "Compile" (without the quotes) on the commandline
Locate and select the fencex.shp file and click open.
The command line should show this
"Compiling shape/font description file
Compilation successful. Output file D:\My Documents\Cad\AWP Cad Setup\Line Types\FenceX.shx contains 100 bytes."
Using windows explorer, copy the resulting FenceX.shx file into a folder in your support path.
Back in autocad, load the linetype from the FenceX.lin file.
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Andrew that seems to have done the trick![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
no working for me at all. guess i'll have to give up.
but i appreciate all your help guys.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you tried the linetypes that ship with Civil 3D? There are two barbed wire fences in the AeccLand.lin linetype file that contain an "X" that stay centered in the line as the line is rotated.
Peter Funk
Peter Funk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
wow...the barbed wire line types in AeccLand.lin are perfect. had no idea they were there.
thanks so much.
