• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    neilyj
    Re: Why does my linetype change if i rotate passed 180 degrees?
    11-01-2012 12:45 PM in reply to: cadman33619
    I can't get this to work at all...:smileyfrustrated:
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    *Expert Elite*
    AllenJessup
    11-01-2012 12:54 PM in reply to: neilyj
    If either of you want to email me a jessupa at co.rockland.ny.us I'll send both files to you.
    Attached is a file created in 2012 and saved to 2007 with the linetype shown in it.
    Allen
    Distinguished Contributor
    11-01-2012 12:59 PM in reply to: AllenJessup
    i see..
    ok im getting bad definition on line 2. i copied yours exactly.
    *Expert Elite*
    AllenJessup
    11-01-2012 01:15 PM in reply to: cadman33619
    I've reviewed the creation of custom linetypes from the 2012 help files. The only difference I see is that they now specify the the .SHX extension. Like this:
    *FENCEX,Fence with Xs
    A,1.0,-0.09848,[FENCEX,FenceX.shp,s=.05],-0.09848,1.0
    I also see that in the original post I said to rename the the file to a .SHP file. It should be a .SHX file.
    Allen
    *Expert Elite*
    neilyj
    11-01-2012 01:56 PM in reply to: neilyj
    Still no luck - I'll try again tomorrow with fresh eyes...
    neilyj
    Distinguished Mentor
    11-01-2012 06:57 PM in reply to: neilyj
    you need to compile the shp file first.
    In autocad type "Compile" (without the quotes) on the commandline
    Locate and select the fencex.shp file and click open.
    The command line should show this
    "Compiling shape/font description file
    Compilation successful.  Output file D:\My Documents\Cad\AWP Cad Setup\Line Types\FenceX.shx contains 100 bytes."
    Using windows explorer, copy the resulting FenceX.shx file into a folder in your support path.
    Back in autocad, load the linetype from the FenceX.lin file.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    *Expert Elite*
    neilyj
    11-02-2012 01:53 AM in reply to: andrewpuller3811
    Thanks Andrew that seems to have done the trick:smileyhappy:
    neilyj
    11-02-2012 06:17 AM in reply to: neilyj
    no working for me at all. guess i'll have to give up.
    but i appreciate all your help guys.
    Employee
    11-02-2012 06:41 AM in reply to: cadman33619
    Have you tried the linetypes that ship with Civil 3D? There are two barbed wire fences in the AeccLand.lin linetype file that contain an "X" that stay centered in the line as the line is rotated.
    Peter Funk
    Autodesk, Inc.
    Peter Funk
    Autodesk, Inc.
    11-02-2012 07:15 AM in reply to: peterfunkautodesk
    wow...the barbed wire line types in AeccLand.lin are perfect. had no idea they were there.
    thanks so much.
