• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    jaybwise
    Why can't I see contours on my surface?
    351 Views, 2 Replies
    03-27-2012 07:32 AM
    I create a surface. Then add a point file. The Surface boundary shows up but I see no contours or triangles. If I 3drotate and esc from that command I can then see triangles.
    I need to show contours, or better yet colors, to provide a good visual of the existing ground.
    Please use plain text.
    Re: Why can't I see contours on my surface?
    03-27-2012 07:41 AM in reply to: jaybwise
    did you use a surface-style that is setup to show contours?
    Select the surface, right-click to get the context-menu ==> modify style and look then
    a) within contours-tab to set the distances
    b) in the display-tab check if contours are switched on or off (for both, 2D and 3D separately)
    - alfred -
    Alfred NESWADBA
    jtshumpert
    03-27-2012 12:09 PM in reply to: jaybwise
    Right click on your surface and select Surface properties.
    Set your "Surface Style" to a style that has contours.
    JTS
    http://civil3dit.com/
