• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Where are the defaults for Add Contour Data: "Minimize flat areas by:"?
    159 Views, 8 Replies
    02-05-2013 12:39 PM
    When I add contour data to my surface, I uncheck all the boxes in "Minimize flat areas by:"  except "Swapping edges", and I check the "Swapping edges" box.  The next time I add contours, I have to uncheck the same boxes, and check the "Swapping edges" box.  I can set the default Mid-ordinate distance, etc. but I can't find anywhere in the settings that I can preset the check boxes for minimizing flat areas.  Please help.  This has been driving me bonkers.
    I have attached a screen snip, showing the items I want to preset.
    Thanks for your help.
    Max J. Lorenz II
    Technical Designer III
    AMEC Environment & Infrastructure, Inc.
    Civil 3D 2012
    Intel Xeon W3670 @ 3.20 GHz
    12 GB RAM
    NVIDIA Quadro 600
    Please use plain text.
    Valued Contributor
    Re: Where are the defaults for Add Contour Data: "Minimize flat a
    02-05-2013 12:46 PM in reply to: mrbbq1965
    Navigate to the Toolspace, then the Settings tab. Scroll down to Surface and expand it. Then expand the Command folder under Surface, you can right click on any of these cammands to change the default settings and vaules. Hope this helps.
    Gunnar
    BrianHailey
    02-05-2013 12:54 PM in reply to: mrbbq1965
    To expand upon what gunnar said, you can access those settings here:
    And if you are interested, HERE is a post I created on my blog explaining my recommendations for adding contour data to a surface.
    Valued Contributor
    02-05-2013 12:56 PM in reply to: gunnarl
    I've been through those, but I can't find the specific settings that control those exact four check boxes.
    Valued Contributor
    02-05-2013 12:59 PM in reply to: BrianHailey
    For some reason, I don't get those options:
    Valued Contributor
    02-05-2013 01:07 PM in reply to: mrbbq1965
    Another designer here at work checked, and those options are not availabe to him either.
    Did those options only come about in 2013?
    BrianHailey
    02-05-2013 01:09 PM in reply to: mrbbq1965
    Yes, they are new in 2013.
    Valued Contributor
    02-05-2013 01:23 PM in reply to: mrbbq1965
    I didn't realize it was a 2013 only feature. Sorry about that.
    Valued Contributor
    02-05-2013 01:28 PM in reply to: gunnarl
    Thanks for your help, Brian.  Maybe we'll get an upgrade one of these days.
    As far as creating existing surfaces from contours, I check all four as you suggest.  When I'm adding contours to clean up finished grade contours (as I'm doing right now), I don't like the results of all those options turned on.
