• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Where are Map 3D built-in workflow files?
    209 Views, 6 Replies
    02-12-2012 01:38 PM
    I am running Civil 3D and trying to learn Map 3D.  The user manual talks about workflows and built in files:
    If you do not see the built-in workflows in the drop-down list of workflows, click Open Workflow From File in that list and navigate to the Program Files\Autodesk\AutoCAD Map 3D 2012\Sample\Workflow folder. Select the .xoml file for the workflow to open.
    I have tried to locate these and they are not present in my install.  Any idea where they might be located or are they only part of Map 3D?
    Civil 3d 2011 or 2012
    Quad Core Intel
    Windows 7 x64
    8GB RAM
    Please use plain text.
    AllenJessup
    Re: Where are Map 3D built-in workflow files?
    02-12-2012 01:47 PM in reply to: tjsuchoski
    Not realy sure about that. You might try the Map 3D group. Anyway these are the 12 files I found in my recent install of 2011.
    Allen
    Active Contributor
    02-12-2012 02:21 PM in reply to: AllenJessup
    I tried looking in my 2011 sample files and I found the workflow files there.  But when I look in the 2012 samples, there are no workflow files.  There is a HTML file Where are my sample files which displays:
    Location of Sample Files
    The sample files are now available online and are no longer included on the AutoCAD DVD.
    You can access the sample files at the following URL:
    http://www.autodesk.com/autocad-samples
    Thinking that maybe they would be located on-line, I tried clicking on the link, but it takes me to an Autodesk page for 2010 and 2011.  Not much help on 2012!  Also, no workflow files.
    Quad Core Intel
    Windows 7 x64
    8GB RAM
    02-13-2012 01:33 PM in reply to: tjsuchoski
    What I've learned is that while Autodesk says that those who purchase Civil 3D get Map 3d, they aren't exactly the same. There are differences on where files are located, where menues are, and there are even Map ribbon buttons that just don't work in Civil 3D.
    I know that didn't answer your question directly, but it helps to remember that Civil 3D does not contain the same Map 3D that those who purchase just Map 3D get. If you can't find a file where the Map help files say, do a Windows search on those files and see where Civil 3D placed them, if they even got installed at all.
    Civil 3D 2013 x64
    Civil 3D 2014 x64
    Windows 7 64-bit
    6GB RAM
    neilyj
    02-13-2012 01:37 PM in reply to: engrtech
    Map 3D LT if you will.....
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Distinguished Mentor
    thepworth
    02-13-2012 02:58 PM in reply to: engrtech
    Another "piece of the puzzle" is that the interfaces for Map3D and C3D are by 2 separate teams.  The C3D team didn't / doesn't always put things in the same place as Map (if at all)  frequently, if you can't find an icon for a command, the command line entry will still work.  Go figure.
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Active Contributor
    02-13-2012 04:21 PM in reply to: engrtech
    I did a windows search for .xoml files on the C: drive and came up with nothing.  Does that mean that they were not installed?  If not, might they be available from somewhere else?
    Quad Core Intel
    Windows 7 x64
    8GB RAM
