AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
When publishing a sheet set some of my annotation lables are not showing up.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When publishing a sheet set some of my annotation lables are not showing up. If I open the sheet, they are there, set to print and everything is correct. If I print just that sheet, everything is fine. Only happens in publish. It's almost like the publish command isn't giving the drawing enough time to open and load everything before printing. Is there a way to fix this? Anyone else had the same issues?
C3D 2010 (unfortunetly) hopefully moving to 2013 soon!
Re: When publishing a sheet set some of my annotation lables are not showing up.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We had a similar issue with annotation (profile curve annotation) showing up in one place on the drawing but printing in another place (lower or higher).
It turned out it was an issue with regular AutoCAD and the Object Enabler.
Sorry, probably not much help there.
Is your Civil 3D up to date with the latest service packs and such?
We've had other issues with the default DWGTOPDF and have better luck with other pdf drivers such as AcroPlot Pro and even CutePDF.
Does it happen when you publish just one sheet or multiple sheets?
As an experiment, try publishing to DWF. If successful, you might be able to print the DWF to PDF. But, that's a rather lousy workaround. Then again, I'm assuming you are publishing to PDF.
Just some thoughts.
http://autocad-lkh.blogspot.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You are correct, I am doing DWG to PDF with the publish. It makes printing easier since my sheet sheets are over 100 pages and I can run the publish overnight, then print in the am.
Service packs are up to date and we have CutePDF as well, and it does the same thing. It isn't one specific type of annotation label that isn't pirinting, it's rather random. And it only happens when publishing multiple sheets.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Check your publish settings. (picture attached) In 2011, some of our users have problems with it reverting back to lines overwrite instead of lines merge when publishing multiple sheets. That might cause some of your labels to be hidden.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That is why we use AcroPlot to do our PDFs. DWGtoPDF will start overwriting lines if you publish to a multiple sheet PDF file. I don't know if they fixed it in 2013 or not, but they are aware of the issue. This line overwrite would be a problem if there is something (hatch, wipeout, etc) on top of their lables.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Cansel - Autodesk Division
http://www.cansel.ca/
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have everything set to lines merge, and that seems to be working correctly. Question about your publish settings. Mine are the same except I have "include" on the layer information. You have "don't include". What does that do?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not publishing in the background.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If layers are included, the layer information is displayed in the pdf reader and layers can be turned on or off by the recipient of the file.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry, I'm out of suggestions. You could publish to dwf and create your pdf files from there, but that is an extra step. You might have documented the first-ever case of C3D doing something too quickly.
