• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    What is this?... Again
    187 Views, 4 Replies
    10-01-2012 11:18 AM
    Hello all,
    (sorry, i posted this in wishes by accident first)
    This symbol just started showing up on any drawing I open in Civil 3d 2012.  It also shows up on "Drawing 1" when I start cad. It doesn't have any sort of message when I hover over it, I can't click on it, and everything seems to be working,,,
    I started work this morning in a drawing and it wasn't there, closed cad, started cad, and it was there.
    Has anyone seen this before?
    Sorry if this has been covered; I tried looking for it the boards, but it's hard to describe in the search.
    Rand Waltz
    Please use plain text.
    *Expert Elite*
    Re: What is this?... Again
    10-01-2012 11:20 AM in reply to: rand
    It indicates that Level of Detail is turned on.
    *Expert Elite*
    neilyj
    10-01-2012 11:21 AM in reply to: rand
    It's Level of Detail - found under the View Tab in the ribbon see http://beingcivil.typepad.com/my_weblog/2011/05/autocad-civil-3d-2012-preview-surface-level-of-detai...
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    *Expert Elite*
    neilyj
    10-01-2012 11:22 AM in reply to: neilyj
    You just got to it first Jeff....:smileyhappy:
    neilyj
    Active Contributor
    10-01-2012 11:25 AM in reply to: neilyj
    Wow! Sudden Service!
    Thanks to both of you.  I had opened a drawing with a lidar-based surface earlier and that dialog box popped up.  Earlier I had ignored it but last time I said okay.
    Thanks again!
    Rand Waltz
