• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    What is the best way to create a design surface?
    185 Views, 4 Replies
    01-02-2013 07:40 AM
    I need help creating a design surface from an original surface. The current method I am using is taking alignments and adjusting the elevations on the profile. I would add the alignment as a breakline to create the design surface. Is there a simple way to create a design surface?
    Please use plain text.
    AllenJessup
    Re: What is the best way to create a design surface?
    01-02-2013 07:54 AM in reply to: rvandever21
    Look at help and tutorials on Corridors and Corridor Surfaces.
    TRogers
    01-02-2013 08:37 AM in reply to: rvandever21
    Or you can use Feature Lines.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Active Member
    01-02-2013 09:01 AM in reply to: TRogers
    After I change the elevation of the profile, I change the alignment to a feature line.  Then I add the line as a breakline to the surface.
    Joe-Bouza
    01-02-2013 05:31 PM in reply to: rvandever21
    Design surface is quite a broad term. All the other suggestions apply.
    But could you elaborate on what constitutes your design surface? Parking lot , roadway, subdivision, mining, basins, landfills? There is just so many ways to skin this.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
