What is the benefit to numbering alignments?
deltacoolguy
deltacoolguy
Maybe I'm missing something.  What is the benefit to numbering alignments?
Example:  Street CL (1), etc.
When I have a street centerline alignment, I am failing to see any benefit.  If I have a change, I want the change, not any old stuff.  If I have a need to different alignments for differing purposes, I'd rather give each my own unique name.  If I make a change, and I want that change easily reflected into a profile or corridor, wouldn't it be more efficient to let the name remain constant?
Do you allow the program to do this?
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
Joe-Bouza
Alternate scenario? I know what your talking about, though
Joe Bouza
deltacoolguy
When making changes, instead of "Street CL (1)" --> "Street CL (2)", and so on...
...just name it "Street CL" and allow it to overwrite.
I suppose there may be a benefit, but I am failing to experience a benefit so far.  Don't get me wrong, I am willing to continue this default if there is a benefit (or if allowing overwriting would cause a problem).
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
Joe-Bouza
You dont have to accept the default naming template. You can go an name the alignment Maple Street etc.
Joe Bouza
BrianHailey
You can't have two alignments with the same name so by adding a counter to the naming template, it prevents duplicate names.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
