• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    What is an ADTS Audio file?
    3492 Views, 6 Replies
    06-01-2011 06:10 AM
    civil3d is creating audio files upon fatal error. Does anyone know what these are?
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: What is an ADTS Audio file?
    06-01-2011 06:28 AM in reply to: josephbouza5497
    Hi Joe,
    The ADT files are files that get created when you run AUDIT command. The reason they show up as audio files may be that the default for ADT was set to be one of the programs such as Windows Media Player or Real Player. If you open it with Notepad you will see its content. You may want to change the defaults, too.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Please click on "Accept as Solution" if post helped you resolve the issue.
    06-01-2011 08:09 AM in reply to: AlmasSuljevic
    Hi Almas, do I want to keep those files?
    Product Support
    AlmasSuljevic
    06-01-2011 08:33 AM in reply to: josephbouza5497
    Hi Joe,
    You don't have to. They are good for troubleshooting only in case you want to send them for investigation.
    Almas Suljevic
    06-01-2011 12:21 PM in reply to: AlmasSuljevic
    Good to know. :smileyvery-happy:
    neilyj
    06-01-2011 12:49 PM in reply to: josephbouza5497
    For all the good submitting files to Autodesk does, you'd be better off trying to listen to the files...!!!!!!!!
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Product Support
    AlmasSuljevic
    06-01-2011 12:51 PM in reply to: neilyj
    That'd be fun file to listen. :smileyvery-happy:
    Almas Suljevic
