• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Weed / Sort Points
    162 Views, 4 Replies
    07-09-2012 07:13 PM
    I have a group of COGO points that is tightly spaced, say approx. 2 feet between points and I want to weed them out so that several points in an area are deleted and I am left with approx. 10 feet between points.
    Can this be done in Civil 3d?  I don't want to interpolate points from a surface.
    If anybody is familiar with Hypack software, I am trying to do a 10' sort but in C3D.
    Mark
    Please use plain text.
    *Expert Elite*
    AllenJessup
    Re: Weed / Sort Points
    07-10-2012 05:40 AM in reply to: 907Trekker
    I don't know how to do that but if you can explain why you want to do that. There may be alternatives.
    Allen
    *Expert Elite*
    johnm
    07-10-2012 06:46 AM in reply to: 907Trekker
    I don't know of any automatic method.
    You could build a surface with the points, simplify the surface, display it with points only (points set to mode 0 so they look like a dot), explode it twice, use select similar to select all of the resulting autocad points, copy/paste them to a new dig and convert them.
    It sounds convoluted but it is a pretty short process.
    You would of course lose any descriptions...
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    johnm
    07-10-2012 07:13 AM in reply to: 907Trekker
    I would also wonder if Map can help weeding cogo points but I don't think it works well with C3D objects...
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    Valued Contributor
    07-10-2012 08:17 AM in reply to: 907Trekker
    Could you give every fifth point a different descriptor by editing the point file in a spread sheet, then reimport, and limit your point displays and/or your surface build by creating a point group with those selected new descriptors?
    Civil 3D 2011
    Windows 7 Prof. x64
    HP Z400 Workstation
    Intel(R) Xenon(R) CPU
    W3550 @ 3.07GHz
    6.00 GB RAM
