• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Watershed delineation
    771 Views, 12 Replies
    01-24-2007 01:09 PM
    I just tried using the watershed analysis routine. It left me somewhat confused. The model is in mountainous terrain and was developed from 24k contours. I would like to be able to pick a spot on the surface and have the software delineate the drainage basin discharging at this point. Can this be done?
    Steven C. Devin, P.E.
    Consulting Engineer
    Civil 3D 2007
    Dual Xeon 3.2 MHz
    3 GB RAM
    Nvidia Quadro FX3400 256MB
    Please use plain text.
    *Jason Hickey
    Re: Watershed delineation
    01-24-2007 02:26 PM in reply to: sdevin
    It's on the wishlist.
    Jason Hickey
    Civil 3D 2007, SP3
    Dell Precision M70
    2 GIG RAM, 256 MB nVidia Quadro FX Go1400
    Intel Centrino 2 gHz Processor
    www.civil3d.com
    *Laurie Comerford
    01-25-2007 02:04 AM in reply to: sdevin
    Hi Jason,
    On the wish list or not, it's a fantasy. Any one who tells you they can do
    it has no knowledge of TIN models.
    Unless you pick a point which is exactly on a line in the model where the
    two triangles on each side of the line slope towards the line forming a
    valley, the catchment area to a point is a line. And, as you know a line
    has zero area.
    You could make some sort a guess and get a catchment area which drains to
    the triangle which you pick - or some other convention such as an assumption
    of water depth at the point, or a nominal length of gutter at the point, but
    would you rely on something like this without knowing what the convention
    was and whether that would be realistic in the circumstances of your design?
    The watersheds defined for the TIN model are areas bound by "ridge lines" in
    the model. They are a guide to the user in as much as water from outside a
    catchment cannot get into the catchment because it would have to flow over a
    ridge line to do so.
    Obviously in practice, water in flat country can cross catchment boundaries
    as the water depth can exceed height of the ridge line above the invert in
    the catchment area.
    As an example of this, I once had to analyse a "maximum probable rainfall"
    event. A rail embankment varying from 3 to 7m high (nominally horizontal
    for the trains) ran across several valleys with 6m by 4m culverts at the
    valleys. These culverts were no where near adequate for the event I was
    analysing and water would have flowed between the valleys had the storm
    event occurred.
    At it's peak, it is likely the water would have flowed about a metre deep
    over the rail line over a length of about 6km and washed significant
    portions of the embankment away.
    Laurie Comerford
    CADApps
    www.cadapps.com.au
    www.civil3Dtools.com
    "Jason Hickey" wrote in message
    news:5462837@discussion.autodesk.com...
    Jason Hickey
    Civil 3D 2007, SP3
    Dell Precision M70
    www.civil3d.com
    01-25-2007 08:26 AM in reply to: sdevin
    I believe that HEC-GeoHMS has some sort of routine for delineating watersheds. It pre-processes the surface model and burns in flowlines. It's been a while since I considered using that software package but I remember that this was one of the features that intrigued me especially for a large basin (>100 mi^2) with multiple sub-basins.
    Valued Mentor
    fcernst
    12-19-2012 09:13 AM in reply to: *Laurie Comerford
    USGS StreamStats has a nice watershed delineation tool I use. I picked the outlet point at the top there where I drew the red arrow. It delineated this watershed in about 9 seconds. One pick... no tedious waterdrops required.
    I would like Autodesk to put an inquiry to the USGS about this technology for use in Civil 3D terrain models.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Active Member
    01-03-2013 06:24 PM in reply to: sdevin
    good software Aquaveo WMS
    01-08-2013 09:26 AM in reply to: fcernst
    Fred --
    That looks like a really great tool...where is it on the Stream Stats website?
    Jason
    johnm
    01-08-2013 12:04 PM in reply to: rubaru
    It's the little black dot button. This is a great tool. We have have it in NJ for a couple of years now.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Joe-Bouza
    01-08-2013 06:31 PM in reply to: johnm
    Hey John, Happy new year.
    Stream stats a tool to get?
    I have always understood watersheds to be nebulous so what about catchments?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    johnm
    01-09-2013 06:26 AM in reply to: Joe-Bouza
    Happy New Year Joe!
    Stream Stats is free. It is available in NY. Other users can check here to see if it's available.
    http://streamstats.usgs.gov/ssonline.html
    It's very nice. Just as Fred said. Click a point and the watershed is delineated. Peak flows for a range of storm events can also be computed for you.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
