• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    WEIRD ZOOM ISSUE WHEN ENTERING MODEL SPACE
    194 Views, 6 Replies
    12-08-2012 03:32 PM
    whenever i enter model space, or open a drawing the drawing zooms to some odd isometric view.  zoom previous fixes this, but it has become annoying quickly.  i read this was a bug fix in SP1, but i JUST installed civil3d2013 2 days ago.  it doesnt seem to happen in all my drawings.
    Please use plain text.
    Active Contributor
    Re: WEIRD ZOOM ISSUE WHEN ENTERING MODEL SPACE
    12-08-2012 03:39 PM in reply to: boyerengineering
    I also noticed that when switching to model space ucsfollow keeps returning to 1.  i want it set to 0 so i can enter viewports with out it zooming extents constantly.
    *Expert Elite*
    BrianHailey
    12-09-2012 02:27 PM in reply to: boyerengineering
    Just to verify, did you install the service pack when you installed C3D? The install files aren't updated with the service packs, they still need to be added. You can install the service packs as you install the program however.
    Active Contributor
    12-10-2012 07:34 AM in reply to: BrianHailey
    Thanks for the response.  yeah, i ended up installing the SP and it fixed that problem.
    Member
    03-28-2013 05:35 AM in reply to: boyerengineering
    Hi
    I have a quite similar problem.
    Whenever I enter model space, or open a drawing, it zooms to some view where I can't see anything.  Zoom previous fixes this too. It doesn't happen in all my drawings either.
    Otherwise if I do several undos then I get the previous view but it closes some XREFs !
    I use a french version of Map 2013, with an add-on called COVADIS.
    Service pack 1 has been installed.
    Any suggestion welcome.
    Autocad Map 3D 2013 - COVADIS (french)
    *Expert Elite*
    03-28-2013 05:53 AM in reply to: JC000
    UCSFOLLOW     ?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Member
    03-28-2013 08:17 AM in reply to: troma
    Thanks for that.
    UCSFOLLOW is set at 0, never changes (that I can see).
