• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor jle
    Active Contributor
    Volumes Dashboard Cut/Fill Report
    491 Views, 3 Replies
    12-28-2011 03:06 AM
    The Cut/Fill report from Volumes Dashboard generates 'blind' totals when using Bounded Volumes. This way every Bounded Volume amounts to the original data which ofcourse is stupid.
    How can I fix this in the CutFillReport.xsl in the folder C:\ProgramData\Autodesk\C3D 2012\enu\Data\Cut Fill Report\...
    or Autodesk please have this fixed in an update.
    Volumes_Dashboard
    Thx!
    John
    Please use plain text.
    neilyj
    Re: Volumes Dashboard Cut/Fill Report
    12-28-2011 03:43 AM in reply to: jle
    Not sure what you mean by "blind" totals??
    if you untick the main surface when creating the bounding polygons the total isn't shown in the report (don't have C3D on this PC so can't do screenshot)
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Active Contributor
    12-28-2011 04:00 AM in reply to: neilyj
    Get your point, there are 2 ways of using the Volumes Dashboard.
    1. Main Volume Surface completely devided by bounded areas(and thus volumes)
    2. Main Volume Surface partially devided by bounded areas (and volumes)
    My situation is 2 and then I need a report with the total area and volume of the main volume surface but also the separate bounded areas and volumes. In this case the Totals in the report shouldn't be adding everything up but only the main surfaces.
    Ofcourse in situation 1 you can uncheck the main surface and have all bounded areas summed up which should be equal to the main surface data.
    Does this clarify my point?
    neilyj
    12-28-2011 12:59 PM in reply to: jle
    Still not really sure of the problem here (mainly as I can't access C3D at the moment) but I may be a bit confused by the dataset you've provided.
    My understanding of the problem is if, for example,  the whole volume surface was 2500 cu.m. and two polygon areas were 500 cu.m. and 500 cu.m. each, then the total volume would be reported as 3500 cu.m which is of course incorrect (and a bit of an annoying "bug")
    Whenever I've used the Volumes Dashboard I simply copy and paste to Excel and do the formatting and computations I require there.
    neilyj
