• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Volume of Fill
    173 Views, 4 Replies
    01-07-2013 01:02 PM
    Hello!
    Could some one please help me with this:
    I have an existing survey surface, and I want to know how much cubic yard of materials to fill up from the bottom to elevation 876. See attached image for detail. Here is what i am going to do and please correct me if my way is right way to do or not:
    - i will create a surface of the fill area (from bottom cotours up to el 876) then do a volume surface bwt existing ground surface and the new fill area surface to get the volume of it? Is this a right way to do?
    Thanks and Regards.
    Please use plain text.
    neilyj
    Re: Volume of Fill
    01-07-2013 01:21 PM in reply to: SeattleCADD
    If the finished surface is all at 876 then extract the 876 contour and use that as a breakline/boundary in a new surface then volume surface with EG as base and 876 surface as comparison.
    OR
    draw a rectangle at 876, create a surface from it and use this as the comparison surface (possible easier as no triangles to trim out on concave areas)
    OR
    You could also draw a rough pline around the 876 contour and run reportsurfboundedvolume with the pline as the boundary and specify a datum of 876.
    Incidentally at the top left of the screendump the contours appear to drop down to around 873.5 in which case this will be calculated with a vertical "cookie cut edge" which may or may not affect the volume greatly
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Re: Volume of Fill
    01-07-2013 01:39 PM in reply to: neilyj
    Please patience with me as i am a new in C3D.
    "draw a rectangle at 876, create a surface from it and use this as the comparison surface (possible easier as no triangles to trim out on concave areas)"
    You meant: draw a rough pline around 876, create a surface from this contour line and do a volume surface with EG as base and surface 876 as comparation? i am not understanding? Keep in mind that i want to know the volume of fill material FROM THE BOTTOM OF THE EG surface (el 873) UP TO EL 876?
    Please help!
    Re: Volume of Fill
    01-07-2013 02:51 PM in reply to: SeattleCADD
    Please see attached for better understanding my question. Thanks,
    Re: Volume of Fill
    01-07-2013 06:35 PM in reply to: SeattleCADD
    Yup - I would do the second option.
    Draw a feature line, elevation = 876 around your area of interest but slightly larger.
    Create a surface
    Select the featureline, right click and add to surface as breakline.
    Analyze/Volumes, selecting your EG as the base and your 876 elevation surface as the compare. Ignore any cut values.
    Eric Collins, P.Tech.(Eng.)
    Win XP Pro SP3 32 bit
    Xeon E5520 @ 2.27 GHz
    4 GB RAM
    Civil 3D 2012
