• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    mattsears18
    Accepted Solution
    Volume comparisons in Civil 3D 2012
    1140 Views, 4 Replies
    03-06-2012 04:38 AM
    I learned everything on AutoCAD Civil 3D 2010. I remember a while back, I created two surfaces to do a volume comparison. Mainly I was interested in a cut/fill analysis. When I compared the surfaces, it created a new volume entity (for lack of knowing what it was technically called). The icon for this new entity was different from the icon for a surface; the new icon looked more like an extruded version of the original surface icon, if that makes sense. From here I was able to color areas that were in cut or fill, plus all sorts of other visual things.
    So my problem: I am now using AutoCAD Civil 3D 2012. I have successfully created two surfaces and done a volume comparison. I can get the cut/fill from panorama, but I don't see any new entity created for this comparison. I am interested in coloring my plan for areas of cut and fill, for a quick visual representation. Has this feature been eliminated or changed in 2012, or am I missing something? Is there possibly something extra that I need to install? I am using the student version, but I have always used student versions.
    Please use plain text.
    *Expert Elite*
    neilyj
    Re: Volume comparisons in Civil 3D 2012
    03-06-2012 07:41 AM in reply to: mattsears18
    Use a surface analyis as per screenshot
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Member
    mattsears18
    03-06-2012 09:59 AM in reply to: mattsears18
    Thanks, I think we're almost there. Some reason I don't have "Levels" as an option. Any idea?
    See attached
    Member
    mattsears18
    03-06-2012 10:10 AM in reply to: mattsears18
    Solved. Had to create "TIN Volume Surface." That's what I was forgetting.
    *Expert Elite*
    neilyj
    03-06-2012 12:48 PM in reply to: mattsears18
    Glad its sorted - my version is UKIE specific and so refers to Levels rather than Elevations
    Please could you mark as solution (and give kudos) :smileyhappy:
    neilyj
