• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    mattsears18
    Volume comparisons in Civil 3D 2012
    1141 Views, 4 Replies
    03-06-2012 04:38 AM
    I learned everything on AutoCAD Civil 3D 2010. I remember a while back, I created two surfaces to do a volume comparison. Mainly I was interested in a cut/fill analysis. When I compared the surfaces, it created a new volume entity (for lack of knowing what it was technically called). The icon for this new entity was different from the icon for a surface; the new icon looked more like an extruded version of the original surface icon, if that makes sense. From here I was able to color areas that were in cut or fill, plus all sorts of other visual things.
    So my problem: I am now using AutoCAD Civil 3D 2012. I have successfully created two surfaces and done a volume comparison. I can get the cut/fill from panorama, but I don't see any new entity created for this comparison. I am interested in coloring my plan for areas of cut and fill, for a quick visual representation. Has this feature been eliminated or changed in 2012, or am I missing something? Is there possibly something extra that I need to install? I am using the student version, but I have always used student versions.
    Please use plain text.
    neilyj
    Re: Volume comparisons in Civil 3D 2012
    03-06-2012 07:41 AM in reply to: mattsears18
    Use a surface analyis as per screenshot
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Member
    mattsears18
    03-06-2012 09:59 AM in reply to: mattsears18
    Thanks, I think we're almost there. Some reason I don't have "Levels" as an option. Any idea?
    See attached
    Member
    mattsears18
    03-06-2012 10:10 AM in reply to: mattsears18
    Solved. Had to create "TIN Volume Surface." That's what I was forgetting.
    neilyj
    03-06-2012 12:48 PM in reply to: mattsears18
    Glad its sorted - my version is UKIE specific and so refers to Levels rather than Elevations
    Please could you mark as solution (and give kudos) :smileyhappy:
    neilyj
