• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Volume calculation for 3D Faces object
    218 Views, 6 Replies
    01-09-2013 11:00 AM
    Hi:
    I have a volume in my CAD file described by 3D Faces. Is there anyway to know what is the volume of this volume -that represents an open pit-?
    Every time that I do a volume I do by the comparison of 2 surfaces but this is not the case now.
    Thanks in advance
    Rafael
    Please use plain text.
    *Pro
    Re: Volume calculation for 3D Faces object
    01-09-2013 11:14 AM in reply to: RafaelMoreno
    in order to get the volume of a pond for instance if it is filled to elevation 979.00
    a flat surface using a rectangle with elevation 979 which is larger than the pond is used to compare to the pond surface.
    does this make sense?
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    *Expert Elite*
    01-09-2013 11:24 AM in reply to: RafaelMoreno
    Do the 3D faces represent the pit, or the volume of the pit?  The way you wrote it makes me think the latter.  Where did they come from?  It is possible that a Volume surface was exploded or had the 3D faces extracted from it.  If that is the case, you need to build a surface from the 3D faces and another surface at elevation zero, and compare the two.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    01-09-2013 01:36 PM in reply to: troma
    Hi Troma, thanks for your long replay:
    The 3D faces that I have represent the Pit. So trying to to clean the file in order to get the 3D faces that represent the surface of the pit is almost....impossible.
    There is not way tof calculating the volume taking the 3D faces in the way I am describing?
    Rafael
    *Expert Elite*
    01-09-2013 07:54 PM in reply to: RafaelMoreno
    Civil 3D only calculates volumes using surfaces. You'll need to create surfaces and then calculate volumes. I doubt AutoCAD itself can do any such volume calculation.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    *Expert Elite*
    01-10-2013 05:27 AM in reply to: RafaelMoreno
    What do you mean about 'Cleaning' the file?
    If you have 3D faces that represent the pit, you can use them to build a TIN surface that duplicates them exactly.
    Then you need to create another surface at the top of the pit.  That will either be flat, as described earlier by others, or you could match it to the top of slope of the pit.
    You can then calculate a volume between the two surfaces.
    01-11-2013 11:38 AM in reply to: troma
    Hi:
    Thanks for the solution. I was lucky that the file came not only with the Volume that descrbed the pit but also with the Surface that described the same pit in a different layer, then I build the surface so I can now calculate the volume comparing this surface with the Original Ground surface
    Regards
    Rafael
