• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    mconosciani
    Visualization/Movie/Video/Snapshot options for pre and post developement
    142 Views, 4 Replies
    07-07-2011 01:12 PM
    What I would like to do is show the progression from existing contour to proposed contour/features as an incremental video (approximately 1 minute long)? Can this be done and what would be a good resource? I do not need/want all the 3D Max options.
    Please use plain text.
    Re: Visualization/Movie/Video/Snapshot options for pre and post developement
    07-11-2011 07:14 PM in reply to: mconosciani
    If you don't mind doing it manually, you can just capture screen shots in Civil 3D. If you want an actual animation that you can save to a file, either 3ds Max Design or Navisworks Manage/Simulate. Navisworks Timeliner feature is designed specifically for what you are describing.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Active Member
    mconosciani
    07-21-2011 07:51 AM in reply to: mconosciani
    how do you capture screen shot in civil 3D? Do you mean print screening? What I would like to do have is a screen shot every proposed contour (ie 1000 through 1050 for example).
    07-21-2011 08:13 AM in reply to: mconosciani
    If you use AutoCAD's Render command in Civil 3D, you can save snapshots of your project to various image file types.
    Tim Corey, Owner
    Redding, CA
    civilspace
    07-21-2011 08:38 AM in reply to: mconosciani
    To capture a screen shot of just the viewport, use JPGOUT or PNGOUT.
    Anthony
