AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Viewport label issues
- Highlight
- Email to a Friend
I'm having an issue with my c3d labels between layouts of the same scale, I have several 11x17 layouts in paperspace at 1:200 scale, no issues between these, but when I added a legal, letter and 11x17 portrait layout at the same scale my C3D label size is significantly smaller, probably 1/10th the size of my original layouts, all my layouts have the same view of the model space with same scales
Any thoughts?
Re: Viewport label issues
- Highlight
- Email to a Friend
Check the units in the page setup. If you're in metric, these need to be mm, but often get set to inches when using inch-sized paper.
If you're in imperial they need to be inches.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
Are you sure that you're plotting all of the layouts at 1:1 (or the same scale) using the same units?
- Highlight
- Email to a Friend
That did the trick, Thanks!!!!
